Quantcast
An Android TV box to replace a fire TV stick
Giraffe76
Hi all,
I was wondering if anyone can recommend an Android TV box to replace our fire TV stick for about the same price if possible
Thanks in advance
Kind regards Mark
bubblegum57
You can buy pretty much Android box, if you are prepared to accept, that there will probably be no updates. So, in a couple of years it will be out of date.
Also, some android boxes are not certified, so netflix won't work. See this chart below.
If you are prepared for some DIY, then a Pi 4 with Libreelec might be for you, or look at Coreelec
I have a 4K Firestick, Nvidia Shield, & a couple of android boxes, with Coreelec installed.
I'd get another Firestick, if you just want plug n play
