bonzobanana
Available from dabs here;
http://www.dabs.com/uk/productView.htm?quicklinx=2X3B
Some info on it here;
http://translate.google.com/transla...l+%22dvd+audio%22&hl=en&lr=&ie=UTF-8&oe=UTF-8
Multiregion hack info etc here;
http://www.nevatech.co.uk/ronin-support-website/pages/amwp80l.htm
No full reviews on the internet that I have found but the feb issue of What video carried a review but its not accessible from their website yet (www.electrictown.co.uk). They claimed the price of the player in the review was £90.
The player is based on the same chipset as the Compacks DVD5000 but has added functionality.
The important features are;
PAL and NTSC progressive scan with a large amount of adjustment allowed to tailor it to your equipment.
The 5.1 decoder features dd, dts, 5.1 matrix options (not sure if its full on dp2 or just a virtual surround clone of it) plus full range DVD audio. It also has optical and coaxial output sockets.
Its compatible with a wide range of formats.
The dvd loader is meant to be very good both fast and very compatible with media.
The What Video review states no RGB scart output where as other sources says it has. So don't know what the end verdict is.
Would probably be an excellent pairing with these 5.1 headphones.
http://www.afterhours.co.uk/Shop/51head.htm
This shop is run for the benefit of a neuro rehabilitation unit so you'd also be helping an excellent cause.
