Amstrad V2 Disk Space Problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jshaw_82, Sep 11, 2005.
  1. jshaw_82
    jshaw_82
    Dec 13, 2004
    185
    Derby
    +3
    I have an Amstrad V2 Sky + box, ive only had it for about 1 month but it is a reconditioned unit. I have just recently noticed that the amount of space left on the box was 51%, so i checked the recorded programs they are just over 2 hours long in total and the little yellow indicator for each program is not much so there is about 35-40% space missing! So i did the Planner Rebuild, same again, i am going to do the Full System reset tonight once i have watched the 2 progs on it, but does anyone have any idea why this would have happened...
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    A long running and seemingly impossible to fix software bug that SKY and it's suppliers should be ashamed about:(
    Just keep your eye on it, planner rebuild should have cured it and the reset will but as you know you lose your recordings.
  3. jshaw_82
    jshaw_82
    Dec 13, 2004
    185
    Derby
    +3
    Do you suggest i call sky or should i just live with it...
