Amstrad Sky+ - RGB Passthrough ?
Discussion in 'Sky Digital TV Forum' started by wandersen, Sep 2, 2004.
  1. wandersen
    wandersen
    Does the Amstrad Sky+ box have RGB passthrough ?
    I am connecting my system as follows:
    Pioneer 575 -> Sky+ -> TV
    When I swtich on the DVD, the picture switches off ...
    Thanks.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Yes it does.
    I would expect the Pioneer being first in the chain to override the SKY+ when it switched on, wouldn't it make more sense to have the SKY+ RGB scart to feed the DVD recorder then onto the TV?
  3. wandersen
    wandersen
    Yes - I wish that that DVD player had two scarts, but it only has one. I think the only other option for me for 2 x RGB inputs would be to use a scart switch.
    I'm going to check later to ensure that RGB is switched on on the pioneer, and take it from there ...
