Amstrad Sky+ Remote problem (take 2)
Discussion in 'Sky Digital TV Forum' started by pinter75, Sep 8, 2004.
  1. pinter75
    pinter75
    Aug 4, 2004
    15
    Ok, as this post didn't post correctly 1st time, I'll start again.
    My Amstrad Sky+ box which is 5 days old has been giving me grief since day 1. After the box has been on for a while, the remote control suddenly stops working. Sometimes for 20 mins, 2 hours or over night. The front panel works ok, so does the TV (so not the remote). The strange thing is that the remote will work if it is right upto the remote sensor on the box? Finally sometimes the box will resond to one command then no others for ages!
    Is this a common fault with the amstrad boxes or is mine a dodgy one?
    Sky are coming out on friday to look at it - but I bet it behaves itself :-(
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    If they swap the box make sure you get a brand new replacement, they are buggers for trying to dump refurbs for under warranty swap outs.
  3. pinter75
    pinter75
    Aug 4, 2004
    15
    They said that I will get a new unit if it needs to be swapped out. I will only accept refubs after 6 months since new - which is not really fair considering the 12 months warranty.
  4. luggsie
    luggsie
    Aug 18, 2004
    199
    South East
    +8
    Just an outside possibility, check there is no interference at the SKY IR sensor from another remote that something is resting on and pressing a button continuously, or else have you a video link with an IR emitter which is playing up near the SKY box. Strong sunlight falling on the sensor used to be problem years ago but shouldn't be by now.
    luggsie
  5. Fernsehman
    Fernsehman
