amstrad losing signal
Discussion in 'Satellite TV, Sky TV & FreeSat' started by andrew12, Aug 26, 2005.
  1. andrew12
    andrew12
    any body help with a prob on rf2 output on my amstrad DRX180?
    a couple of months ago i ran a rf lead to a second location in my house tuned the second tv and everything worked fine, but yesterday it has lost the signal
    and no amount of tuning is bringing it back! it is as if there is no output from the box,have checked that the rf2 is turned on and that the channel number has not changed, any suggestions
  2. Cupra R
    Cupra R
    Jul 18, 2005
    75
    Andrew, have you got a TV linkup (magic eye) on your other set in the other room? if so is the little red LED lit?
    I had a similar problem a short while ago after pulling the TV out from the corner, when it went back the upstairs TV didn't have a signal, but after a little fiddling with the wires on the back of the sky box, the signal was back and the picture was very good quality too.
    Worth a try perhaps...
  3. andrew12
    andrew12
    thanks cupra R yes have a magic eye will give it a try
