Question Amstrad dxr890-c screw driver required?
tony_park
Hi everyone,
anyone any idea what type of screw driver is required to open this box. Seems to be security screws holding the black plastic case in place on the sides. 2 screws, that my usual screw drivers don't appear to fit.
Tony
JayCee
A standard DRX890-C box normally has 2 Philips screws at the rear which secure the side panels (which slide off towards the rear after lifting their retaining plastic clip on the bottom) and 1 Philips screw under the viewing card drop-down flap on the front.
It's then just a case of levering gently up the 3 latching plastic clips on the front underside and the whole chassis then slides out.
I've never come across torx screws on any DRX890-C so I suspect someone has used these in place of the ones normally used.
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
