amps & receivers
Discussion in 'AV Receivers & Amplifiers' started by villaceltic, May 24, 2003.
  1. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    Right I'm going to bite the bullet now and admit that I'm confused over the difference between an amp and a receiver - there I've said it..
    The confusion mounts further when I look at same brand amps and receivers which would appear to have the same features (Dolby pro logic II, 6.1 surround features, etc.)
    If I've got TV, Sky, VCR, DVD and speakers - what should I be looking for - an amp or receiver?
    Macca:blush:
  2. nathan_silly
    nathan_silly
    A AV Reciever is the same as a AV amp, except the AV Reciever has built-in tuner.
    I would say go for the AV amp, and buy a seperate tuner.
    Tuners are noisy devices (lots of RF) so putting that lot into unit which has low-level pre-amp, processing and amps is IMO a bad idea.
    A AV amp ....
    http://www.richersounds.com/index.php?f=itemdetl.php&p=206426
    A AV Reciever..
    http://www.richersounds.com/index.php?f=itemdetl.php&p=206590
    Regarding the new sound formats.. don't worry too much about it. As long it has Pro-Logic II, Dolby Digital, DTS- then that's pretty much the minimum. If it has DTS ES, ES etc etc then that's a bonus.
  3. villaceltic
    villaceltic
    May 22, 2003
    84
    Nantwich, UK
    That's it? So maybe a £100 difference between equivalent models for in affect a 'radio'. If I'm going to be more 'cinema' than 'Hifi' then I still get all the gubbins but typicaly cheaper with an amp?
    Ta
    Macca
