Amps general questions, power distribution
Discussion in 'AV Receivers & Amplifiers' started by Snook, Sep 6, 2005.
  1. Snook
    Snook
    I am looking for amps (2nd hand of ebay/these forums, high powered and low cost :) )
    But I am never going to go higher than good quality sereo. (start with a 2 channel setup and move to 2.1)
    I am going to start with some B+W 601 S3
    and I will add a sub later on.
    a few questions...
    1.
    When a 6 channel amp says its has 50 Watts Per Channel and I only use L and R (for sereo) will the 2 speakers get more power, beacuse the other channels are not being used? Or do only some amps do this?
    2.
    Are there any companies that make decent power 2.1 amps (this question may be pointless if the answer to number 1 is yes.)
    Snook
  2. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    Any amp that uses an unstabilised supply, that is most of them, will have a slightly increased ouptut capablilty if they are not all used at once however the effect when using only 2 out of 5 channels will be small. Not really worth bothering about.
    Never heard of a 2.1 amplifier, which isn't surprising as .1 is meaningless in a 2 channel context. The .1 is the low frequency effects channel for film bangs and thumps and is treated differently from the normal LF content. Any half decent sub will have its own amplifier and filter to enable decent integration with the rest of the system.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    not meaningless, although i disagree with it, a high quality sub apparantly does wonders for stereo, especially when using smaller stand mounts. although i dont think there are 2.1 amps, you can use L and R preouts on any amp (for example tape record channel) and the sub will filter out the frequencies it wants.
  4. skinnyfat
    skinnyfat
    Or get a sub with high level inputs, much of a muchness I suppose :)
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    2.1 is meaningless. Even if you used a sub within a stereo system the signal available would still only be 2.0.
    The 2.0, 5.1, 6.1 and so on refer to the digital/analogue signal supplied to the amplifier rather than what you do with the signal to feed it into your speaker arrangement. :)
