Amplifiers With SCART Switching
Discussion in 'AV Receivers & Amplifiers' started by nheather, Oct 20, 2004.
  1. nheather
    nheather
    Oct 6, 2004
    17,440
    167
    Horsham, West Sussex
    +6,795
    I'm looking for an AV amplifier that does SCART (must be RGB) switching. Basically I want an easy to use solution where both the audio and video sources are corrected selected by a single action.
    The only ones that I am aware of are the Pioneer 301, 402, 501, 502 series.
    Some Panasonic amps do have SCARTs but only support composite.
    Are there any others ?
    Cheers,
    Nigel
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    The Arcam AVR250 and 300 models support RGBS (Scart) switching via their component + composite inputs; there are three inputs and one output and the internal OSD is available on the output. You will need suitable SCART to phono cables; QED and others do these. See www.arcam.co.uk for more info.
    HTH.
    John Dawson (Arcam)
  3. nheather
    nheather
    Oct 6, 2004
    17,440
    167
    +6,795
    John,
    Out of my price range I afraid, but thanks anyway.
    Cheers,
    Nigel
  4. Smeggy
    Smeggy
    Mar 30, 2005
    4
    Bracknell
    Hi Everyone,
    I would like to resurrect this thread as the information is 5 months old. I like the look of the Pioneer 502 Amp because it supports RGB through SCART, so I can connect my Pace NTL box via SCART/RGB, Pioneer DV-575 via SCART/RGB and my VCR via SCART/Composite and finally my Sony 32DX40 TV via SCART/RGB.
    Are there any other NEW suggestion for AV Amp or AV Amp/Recivers with SCARTS. It must have 4 SCARTS at least 3 must be RGB (including the TV).
    or
    Any other suggestion on how to switch RGB through an amp.
    Budget is £250.00 street price (Richer Sounds has the Pioneer 502 for £250.00).
    Thanks for you help in advance.
  5. mjn
    mjn
    May 24, 2001
    22,096
    Herts, England
    +9,850
    I doubt you'll find an amp with 4 SCARTS, and with a budget of £250, you've got no chance!
  6. Smeggy
    Smeggy
    Mar 30, 2005
    4
    Bracknell
    Thanks for your quick reply mjn,
    I do have a chance because that is what the Pioneer 502 is, a £250 Amp with 4 SCARTs. If Pioneer can do it then maybe someone else can.
  7. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    well if the pioneer has everything you want within your budget, i'd recommend buying it!
  8. mjn
    mjn
    May 24, 2001
    22,096
    Herts, England
    +9,850
    The 502 only has 3 RGB SCARTS, plus the 502 is an receiver and not an amplifier.
  9. Smeggy
    Smeggy
    Mar 30, 2005
    4
    Bracknell
    Sorry mjn, but I am aware of that.
