evtrados
Hello all,
It's my first post and I'm really excited that I'll be sharing my thoughts, experience and love for music and sound with you all.
As the title suggests, I really think it's time to upgrade my integrated amp. Currently I have an Onkyo A-9010, which sounds OK for what I wanted to have in the past 7 years (including the fact that small kids and more expensive equipment is not really a good idea).
Some context first and some information about my current setup:
As a result, I decided to gradually upgrade my whole setup. I started with getting the Pro-Ject X1, in order to get the most out of my vinyl records and now I want to upgrade my amplifier. As much as I would like to go with separates, they really take too much space, especially if I later decide to get a DAC, phono preamp or something like the Bluesound node to have multiroom audio. Hence, I'm considering an integrated amp (new or used) at around 3K Euros.
The speakers is the last part of my system that I would like to change, since they were a wedding present, so I really want to keep them for at least 5 years more.
So, I did my research in integrated amps and limited my choices to the following:
- Speakers: Yamaha NS-777
- Power: 100W RMS
- Sensitivity: 89 dB/2.83 V/1 m
- Impedance: 6 Ohms
- Sources:
- Turntable: Had an old Stanton T52 since my university days, but last month I bought a Pro-Ject X1. This is my main source of playing music, but since we of course live in the digital age I've also hooked up a bluetooth receiver to the Onkyo to play music from my phone/tablet.
- TV: I have connected my smart TV to the Onkyo using an optical cable, which works fine, since I can simultaneously use the TV's internal speaker together with the optical connection for a better movie enjoyment.
- Laptop: I either connect it to the TV via HDMI and then let the TV output the sound to the Onkyo via the optical connection, or I use an AUX to RCA cable whenever I don't need the TV
- Phone/tablet: As mentioned above, I have also connected an old bluetooth receiver to the Onkyo, so that I can stream music through my phone.
- Yamaha A-S2100/2200 or A-S1100/1200, or even A-S3000 if I find a sweet deal
- Musical Fidelity M6si or the older M6i
- Hegel H360 or H160/190 (there are some used H360's at a good price)
- Technics SU-G700
- Rotel RA-1592
- Atoll IN200 Signature or IN300
- Denon PMA A110 (there are some sweet deals here and there), and last but definitely not least
- Anthem STR Integrated (if I stretch my budget and find a nice deal)
- Will those amps be an overkill for my speakers? Is it possible that I won't be getting the full potential that the amps were designed to deliver and, thus, won't get the best clarity or tonality that I could be getting with more expensive speakers?
- Should I limit my choices to analog-only amplifiers and then add an external DAC that will also have HDMI ARC (even though Hegel's DAC is supposed to be impressive)?
- Since my main source will be vinyl, should I be only considering amps that supposedly have a very good phono stage (e.g., the Yamaha's, Musical Fidelity and the Anthem)? My main reasoning here is that I don't want to buy and amp with an 'OK' phono stage and then also have to pay a few hundred bucks extra to get a good phono preamp.
