sugarmagnolia
So I have been hunting amps for about a month now, and I can pretty much never settle on one, but I have picked out two that If I find for cheap, I will get. These two are the Cambridge Audio Azur 640A and the Arcam Alpha 8r. If I end up never finding a bargain deal on these amps then I'll need some recommendations for others... The reason I created this thread. Give me some great amp recommendations preferably under £100, but I might be able to find deals on ones over that budget so recommend those as well. Which ever amp I decide on will be used to drive Tannoy Mercury 7.2s so it must fit the specification.
Tannoy Mercury 7.2 specs:
Freq Response (Hz): 42 - 32,000
Impedance (ohms): 8
Power Rating (Watts): 50/200 (Continuous/Peak)
Sensitivity (dB): 87
Edit: Also, how would the Arcam Alpha 7r compare against the Azur 640A? I've heard great things about both amps.
Impedance (ohms): 8
