Amplifier recommendation
Discussion in 'Hi-Fi Stereo Systems & Separates' started by max10, Apr 24, 2007.
  1. max10
    max10
    I'm looking for an intergtrated remote control 2 channel amp with a genuinely "mellow" sound. This will be used primarily to listen to the audio outs of a Freeview receiver and a DVD player. Considering anything up to £350. I really don't want an AV amp as I've never heard a budget one that didn't make me go "eek!". :)
    I'd be grateful for any suggestions.
  2. la gran siete
    la gran siete
    Oct 5, 2003
    25,275
    West Sussex
    +1,984
    Rotel and Nad come to mind at that price. Or for £130 you could try this:
    http://www.dv247.com/invt/25947?gclid=CLPt3Nfz24sCFQqgYgodkFzRbw
    loads of wattage for your money
    or if you have very efficient speakers try this:
    http://www.6moons.com/audioreviews/trends/ta10.html
  3. max10
    max10
    Thanks. The Trends Audio and Behringer amps look really interesting. If I still had the spirit of hifi adventure I'd be queuing with my cheque book. :)
    Unfortunately, I'm not a Nad fan, so I think I'll have to pay a visit to my local hifi shop and ask for some brief demos of the most likely candidates. (I don't like hifi shops you see...)
    Thanks again.
  4. Osamede
    Osamede
    Mar 23, 2007
    805
    28
    +41
    The Rotel RA-06 is a simple solution that wouldn't eat up all your budget.
  5. max10
    max10
    The RA-06 seems to be around the £499 mark. Are you thinking of the RA-05?
  6. Mr_Sukebe
    Mr_Sukebe
    Mar 10, 2004
    2,397
    London
    +214
    Rotel never struck me as making kit that was "mellow".
    I'd suggest you look s/h for gear from Musical Fidelity, and if you can stretch to it, some Meridian kit. You might not end up with a remote, but chances are that it'll sound a whole lot better.
  7. s70rmp
    s70rmp
    Oct 26, 2004
    558
    +17
    just got and running in a Cambridge Audio 640a (v1) and VERY happy with it
    only had 5hrs use at the moment but sounds very sweet to me
    only £150 from Richer Sounds.
  8. max10
    max10
    I agree, I used to have a Rotel integrated amp and it did have a quite forward sound.
    s70rmp - was that a specific instore offer? The RS site lists the v2 640A at £299.
    Edit : Found the v1 in the clearance section...
  9. s70rmp
    s70rmp
    Oct 26, 2004
    558
    +17
    yeah should have mentioned it was int he clearance section !
