Amplifier interference
Mr man
Do I need a ground loop isolator?
I have the 3.5mm headphone jack coming out of my laptop and into my stereo, which then obviously amplifies the signal to drive the speakers connected to it, however on the subwoofer output i have a converter that drops the speaker level output coming out of the stereo (only the subwoofer channel) to a line level which then goes into a more powerful amplifier to drive a 12 inch subwoofer. The problem is when my laptop and amplifier is plugged into the mains at the same time I get a horrible buzzing sound although when i unplug the laptop or amp it goes away. I also have similar problems when connecting games concoles. I have read that a ground loop isolater may fix my problem. I would like to know more about how one works and if it will fix the problem. All help appreciated thanks :)
Ari33
It may be the laptop transformers induction coils own electro-magnetic field being picked up by the amp. Try moving the transformer away from the amp if you can and see if the problem persists.
