Amplifier ident procedure
Discussion in 'TAG McLaren Audio Owners' Forum' started by johnson, Jun 14, 2005.
  1. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Does anyone still have the TMA ident procedure for tagtronic amps?
    My new amps are both showing ident unit1 and the procedure i was sent from IAG doesn't work!
    Any help appreciated
    Regards
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    how to change the amplifier ID
    Please follow these steps to assign a new ID to your amplifier:
    Decide which ID you would like to assign - you can use 1 to 9 and the 10
    key to assign the address 1 to 10 respectively
    *REMOVE THE POWER LEADS FROM ANY OTHER TAG POWER AMPS*
    • Power down your amplifier, using the power button
    • Disconnect any connections to the TAGtronic Bus
    • Switch the amplifier on, using the power button
    • Wait until the amplifier has completely switched on - all LEDs must illuminate
    • Use either the remote, shipped with your amplifier or switch the AV32R’s
    remote amplifier by pressing the REMOTE SELECTION amp key
    • Type these numbers: 1 3 3 1, followed by the ID you like to enter.
    Make sure that you do not leave more than one second between each key
    press - don't let your self be detracted by the relays' switching noise or the
    red LEDs flashing.
    • If the keys are pressed correctly, the red and blue LEDs will switch off and
    about 5 seconds later your amplifier will have a new ID, which you can
    check with the AV32R ‘Dual Processor’.
  3. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Thanks Liam,
    That procedure has some definate but subtle changes to the one i received from IAG
    Best regards
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Liam quotes straight from the manual, I assume IAG just misread something in the translation......To "err is human".... It does work honest.... The TAG amp's are the one thing that pulling the mains lead out must be done as the power switch doesn't kill all the electronics inside, sma egoes for upgrading the software which I'd suggest should be the last version available.
