Amplifier channel power distribution
Discussion in 'AV Receivers & Amplifiers' started by rd350ypvs, Sep 19, 2004.
  1. rd350ypvs
    rd350ypvs
    Jun 12, 2004
    52
    +3
    hi, just wanted to know if you use a 5.1 channel amp in 2 channel mode will you be able to use more than just 2 x 60 watts per channel say, i.e could the amp use the power from the unused channels ? giving you a higher power output in stereo ?
    andyw
  2. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    nope - it wont use the extra power to make one/two channels say 2/3 times powerful, as each channel has the same ampifier!
    only way is bi-amp really, tri-amp - depending on what ur speakers can handle. however u would have to physically move wires to do that. however doing this, i dont really know if u say its doubling the power, at this point watts starts to mean nothing.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    What you will often find is that the quoted power is only close to true whilst running a stereo pair. In reality, what you suggest is true as the power output generally drops significantly below what the manufacturer quotes when running more than a stereo pair.
