Amplifier advice
Discussion in 'AV Receivers & Amplifiers' started by Phil43, May 18, 2003.
  1. Phil43
    Phil43
    Aug 16, 2002
    165
    London
    +4
    Dear Readers, I own an 80W per channel integrated amplifier that I use purely for bass >40 hz.
    If I were to connect the + from the left channel and the - from the right channel to my bass machine and just connect the other terminals to each other (This is in series if I remember my physics) will I blow everthing to bits or will I achieve extra power.
    Most of my listening is at modest levels hovever I currently have the integrated amplifier full out to match the rest of my system.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    I think you are talking about bridging the amp for mono instead of stereo. Try a search, I know Power amps can be bridged but you might need to check for an integrated!
    PS dont take my word for all this try searching google and I'm sure a few more people will be around to offer advice.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    Only some amps can be bridged ... they have to have the correct circuitary. If you try to bridge any other amp you're likely to end up with a smoking doorstop.
    Its not work trying. Sell the current amp and buy something higher powered.
    Another thing to note is when you bridge and amp, they tend not to work well with low frequencies.
    Vikki
