Amplification Advice
Discussion in 'Arcam Owners' Forum' started by Dillon, Apr 28, 2005.
  1. Dillon
    Dillon
    Apr 27, 2005
    57
    Nottingham
    I currently have an Arcam A32, and am looking to upgrade my system for home cinema use. I have a lot of DVDs, so surround performance is important, but I also listen to loads of 2 channel stuff, so upgrade would have to be a 'jack of all trades' really. I love my A32s sound, so want to stick with Arcam gear. I came up with the following possible combination options:
    (1) Get a multi channel module for the A32, and then get a 3 channel P35. Disadvantage that there would be no on-board decoding etc.
    (2) Get an AVR300 and use it to decode and for rear / centre amplification, and use the A32 for fronts.
    (3) Sell the A32, and get an AVP700 and either P1000 or P7 (or indeed a P35/3 and keep the A32 too). Only using a CRT, so HDMI handling is not relevant. Buget would not stretch to AV8/P7 due to other upgrades ...
    Timing wise waiting for AVP700 would not be an issue, as my hi-fi kit is still in a shipping container coming from Australia, so will be released (probably) by the time my stuff arrives. The DVD player is also being replaced (an old Sony 725d), probably with either an Arcam 79 or DV29, or Denon 3910.
    My issue is my local dealer has never seen a multi channel module for the A32, so is unable to demo or advise on that option. Not sure what would be the best of the other options - anyone got any advice ??
    As an aside, has anyone used Dynaudio 52Ses with a set up similar to above ? Demoed the Contour 1.3 ses when I got my amp, but my nearest Dyn dealer is some distance from here, so would like opinions on that combo.
  2. steeled
    steeled
    Apr 23, 2002
    484
    28
    Maidenhead
    +53
    Hi Dillon
    I have the 7.1 input module in a DIVA A90 - could not afford the A32 :)
    To use this module you need a DVD player that already has the Dolby Digital/DTS decoding built in. For example in the Arcam range this would be a DV89, DV79, DV27A or DV29.
    The main disadvantage of this type of setup is that you will not get full 7.1 processing (DTS-ES or DD EX). Nor will you get PLII processing on TV and video games.
    HTH
    Dave
  3. Mofar
    Mofar
    Apr 12, 2005
    34
    +4
    If you are satisfied with the power of your A32, I suggest you buy the Arcam AVR300. I'm using this receiver for 4 weeks in a 5.1 setup now and I like it very much.
  4. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Go for option 2. I use my AVR300 biamped on the front 3 channels with a P25/3.
    You can use your A32 in processor mode to do the fronts and biamp them with a power amp. The AVR300 will do the other channels and you could add a further power amp to biamp the rears as well. The world is your oyster as they say.
  5. mrkeeling
    mrkeeling
    If you are happy with 5.1 and if music is your passion (especially hi-res one – DVD-a, SACD) – multichannel board will give you the best results (with the adequate source). Actually, the board is 7.1, so you are future-proof in a way (if players with 7.1 processing show up).
    I am drooling to replace my AVR200 with A90 with multichannel board.
    :beer:
  6. David-Bel
    David-Bel
    Aug 10, 2004
    67
    Dillon,
    I own an A32 with multichannel board fitted together with a pair of Dynaudio Audience 52SE for stereo. Just to reassure you : the Arcam/Dynaudio combination is highly recommendable ! :thumbsup:
    As for the multichannel board, personnally, I use both sets of 7.1 inputs. One for my 'universal' DVD player (and especially for DVD-A/SACD) and the other one with my old Marantz A/V amp that I now use as a processor. In a way, with that sort of set up, you nearly have the best of both worlds... :D
    Cheers,
    David
