amp with audio delay-what's available?
Discussion in 'AV Receivers & Amplifiers' started by allanrose, Aug 30, 2003.
  1. allanrose
    allanrose
    Dec 14, 2002
    38
    hi all
    looking to correct lipsync problem with dvd & plasma
    I know the Denon 3803 has long-enough audio delay function - any other manufacturers or models offer the same?
    alternatively is there any kit which I can stick between source and amp that will offer same function (but cheaper of course!)
    cheers
    AR
  2. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,673
    Newbury
    +215
    i have the 3803 and it does the job admirably, and sounds great too! i also have used alesis kit, such as the midiverb and quadraverb on the analogue feed between source (freeview box, sky etc) and the amp (prior to buying the denon). i actually have these units up for sale on ebay at present (just search for 'Alesis', you'll find them) - one of them may suit you perfectly?
    Chris
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Allan,
    The new Pioneer AX5i has audio delay, as well as the older (and much dearer) AX10i.
    Steve
  4. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    The Pioneer 2011, if you can get hold of it also has audio delay and is a bargain currently.
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,818
    It has audio delay in regards to time alignment for the main channels etc but not a Master Audio Delay to cure Lip-Sync problems.
  6. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Ah I see, bit misleading in the specs :-( Currently still waiting for mine and hoping I get it before they stop making them. Not sure 400 quid more for lip-sync (i-link is no use to me) is actually worth it and hoping I can do the audio delay if required from an HTPC.
    Si
  7. jmack
    jmack
    do you want to delay analoge or digital
  8. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    Well I use the digital out from the Sky+ box although only films are digital at the mo but ultimately the signal is digital.
