rccarguy3
upload
It's a weird kind of room, a big round room 9m by 9m
We only moved in late last year and there were wee tiny ancient speakers already there, so I've just swapped them for better ones
I'd imagine the actual placement isn't perfect, but they're in literally each corner of the room
I'm all ears though (haha) about how to better this. The existing audio cables are very, very thin so I would think I will be looking at biting the bullet and buying better ones then worrying about how to route them!
If you really want four speakers read this. Its no longer used
Quadraphonic sound - Wikipedia
The better method would a avr and use pro logic ii music or something like that, logic 7 etc I'm using a 4.1 system for computer rig
Oh and get a sub, four little speakers in that massive room isnt enough plus you want to use bass management
