Amp upgrade advice
Discussion in 'AV Receivers & Amplifiers' started by fizz, Mar 12, 2005.
  1. fizz
    fizz
    Nov 1, 2004
    704
    +28
    Hi guys, fairly new to all this, ive currently got a pioneer vsx-510 budget amp which ive had for a few years. Finally decided to upgrade. Ive gone for the canton CD1 speakers kit and would like to upgrade the amp. Would appreciate any advice & recommendations. My budget is about £300 which i know isnt a lot but ill be happy if i notice a change in sound quality / level etc.... Thanks in advance.
    fizz.
  2. johnnycab
    johnnycab
    Jan 26, 2005
    84
    Yamaha DSP-AX750 or RXV750.
  3. Jake James
    Jake James
    Or try the Denon 1905 - Got a good review with WHF
