Amp upgrade advice needed £100-£120 budget
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ben0l0, Sep 11, 2005.
  1. ben0l0
    ben0l0
    Currently my system consists of:
    * Mission bookself speakers (Not sure the exact make, similar to 760s)
    * Marantanz CD 63 CD Player
    * Denon TU-260 Tuner
    * Cambridge (A&R) A60 Amp (Very old)
    Im thinking of upgrading the Amp due to its age, and was thinking of spending in the region of £100- £120 but I am willing to buy second hand off ebay. Ive been looking at the Cambridge A5, any suggestions??
    thanks
  2. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    I like the A5, good for the money I thought. Check the balance knob though as I think to get even sound L/R they are often required to be not central - however thay may have sorted that now.
    Mind you second had could open the window to a whole different range.......
    Always nice to have new though.
  3. ben0l0
    ben0l0
    how much would you pay for a second hand a5 ???
  4. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    To be honest, the A&R 60 is an excellent amp and if its still in working order should be comparable to a £100 amp today.
    If you still want to replace it and don't mind second hand, have a look for the Rotel RA-01 and Marantz PM6010, you should be able to get them for around £100.
    Personally, I'd stick with the A&R (they sell for a fair bit on ebay still, something of a classic) and save the money for a better upgrade later on...or buy more music!
  5. ben0l0
    ben0l0
    The problem is its got no CD output, just AUX due to its age. Therefore I keep having to change the leads around to plug in my ipod etc. I dont think the sound quality is what it used to be, it crackles from time to time.
    What would you suggest to be a better upgrade, bear in mind I play a lot of music via itunes and not much through my cd player.
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    I agree, the A60 is a great amp and I think you would need to spend a lot more money to get a significant upgrade, assuming it is in full working condition.
  7. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
  8. ben0l0
    ben0l0
    Dirty volume pot ??How would I fix that? How much are we talking second hand to get a really good amp, bear in mind ill probably upgrade the speakers in a year or two.
    If I stay with the A60, I always find it really fiddly re-connecting the speaker cables with the amp and my Missions due to the position of the controls on the back of the A60. Are there any plugs I could buy to attach to the end of the speaker cables to allow me to connect my amp and speakers easier if I stay with the A60? (Banana plugs maybe ???) thanks
  9. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    Not quite sure about cleaning the volume pot exactly, I think you just spray on switch-clean, but hopefully someone else will help.
    Yes, you can use banana plugs on the amp and they will make things much easier.
    As for an upgrade, for £250 you can get the Musical Fidelity X-80 from here:
    http://www.weymouthhifi.co.uk/website/mf/x-80.htm
    or for £350 the Cyrus 7:
    http://www.lintone.co.uk/offers.htm
    Both are hugely reduced and excellent amps.
    Andrew
  10. ben0l0
    ben0l0
    HOw exactly do they work and what size would I need? And is there much difference in quality.
  11. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    You put the speaker cable in the back/side and screw it into place (or clamp with some)
    There are some who argue that there will be a slight drop in quality, but I'm not so sure (I use them and didn't notice a difference)
  12. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    An alternative could be one of the variations on the T-amp. You should be able to get one plus a decent power supply for your budget
  13. la gran siete
    la gran siete
    Oct 5, 2003
    25,253
    West Sussex
    +1,976
    I use to have an A60 AND CONSIDERED IT AN EXCELLENT AMP. If I were you I'd hang on to it until I could afford something much better but then I'd be looking to spend about £600 or more.Why not get some decent banana plugs?
  14. ben0l0
    ben0l0
    Due to the lack of visual appeal and CD output on the a60 Im thinking of up-ing my budget to £200. Im looking at the Cambridge AZUR 540A £199 from richer sounds as id rather have a new due to some dodgy seller on ebay when your paying several hundred pounds.
    I notice the AZUR 640A is £50 extra but think that may stretch the finances too far. Im simple-tons terms what the main difference between the two and are either a viable upgrade from the Arcam A60 ???
    many thanks
  15. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    If you could stretch to £250, the Musical Fidelity X-80 is a better amp than the cambridge, you could always sell the A60 for about £60 odd.
    You could try second hand on hifi forums such as:
    http://www.hifiwigwam.com
    http://zerogain.com
    http://forum.hifichoice.co.uk
    You can guarantee that anything for sale there will have been very well kept and in excellent order!!
    Andrew
  16. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    Two more options if your upping your budget to £250 are the Rotel RA-01 and the NAD C320BEE. I use the C320BEE with a pair of Mission m70 bookshelf speakers and this combination produces a lovely warm, detailed sound with punchy bass. I was considering the Rotel myself, but one reason I didn't go for it, was that it can err on the side of bright, which when combined with the Missions, could get fatiguing. I'd certainly give the NAD an audition - Richers have them for about £180.
  17. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
  18. la gran siete
    la gran siete
    Oct 5, 2003
    25,253
    West Sussex
    +1,976
  19. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    Yes, eventually I managed to sell them on the dreaded ebay, not for as much as I hoped though.
    I think the problem was a bad choice of speaker to begin with, although there was a huge improvement, they were still lacking in midrange slightly.
    I was toying with the idea of looking at my Ela's, but I'd be too worried about damaging them!
    Andrew
  20. la gran siete
    la gran siete
    Oct 5, 2003
    25,253
    West Sussex
    +1,976
    speakers if old seem to go quite cheap on Ebay. Bought my Duettes for £65 but have since found them to be too harsh in the upper registers. They are 4 ohm speakers.
  21. la gran siete
    la gran siete
    Oct 5, 2003
    25,253
    West Sussex
    +1,976
    Sorry just realised I'm off topic :oops:
