Amp to match Monitor Audio speakers
dkingvr6
Hi all, after advice for a good friend, he isn’t very tech savvy.
He has just brought a set of Monitor Audio Silver 300 floor standers. His old amp is kaput, any suggestions please spend is £400-1.5k, needs to have Bluetooth and Optical in.
Here’s the speaker spec:
3-way
Frequency Response (-6 dB)​
32 Hz – 35 kHz
Sensitivity ([email protected])​
90 dB
Nominal Impedance​
8 ohms
Minimum Impedance​
3.5 ohms @ 146 Hz
Maximum SPL​
116 dBA (pair)
Power Handling (RMS)​
200 W
Recommended Amplifier Requirements​
80 – 200 W
Thanks in advance
Dan
FootHealer
I haven't owned the Silver 300s, but had the Silver 200s for a while. I tried them on a Rotel A11 Tribute, and cannot say that it was a good combination.
Maybe a Marantz amp would be a good option to explore?
Good luck to your friend. Hope he finds something...
Helix Hifi
I wrote it because I’m not so familiar with Bluetooth amplifiers. With digital inputs also.
Helix Hifi
But don’t Rotel have Bluetooth on all their amplifiers? If not, the Denon Dra 800H has it. I believe. Powernode amp too.
An amplifier around 50-100 watts is going to sing with the 300. Yes, Marantz is an excellent match.
Helix Hifi
You don’t say anything about room size. Still I assume fairly large room. Also what sound your friend likes. Amplifiers have their own voicing.
Marantz is on the warm side. Denon too, but more detailed in the tweeter.
Take your friend with you to some local hifi shops. Listen to few amplifiers, this way you/him get an entirely different view then reading the replies here on this tread.
Good luck. Merry Christmas.
londonguy1973
I used to use NAD and Primare amps with my monitor audio speakers and was very happy with the sound on both. Not sure which ones of their models have Bluetooth though.
Helix Hifi
There’s one way to get Bluetooth. Buy an external streamer, the Node2i as example. Or the new Node version. Most forum members calls it the Node 2021 version. Both have Bluetooth.
Then get an amplifier he likes.
dkingvr6
3-way
32 Hz – 35 kHz
90 dB
Nominal Impedance​
8 ohms
Minimum Impedance​
3.5 ohms @ 146 Hz
Maximum SPL​
116 dBA (pair)
200 W
80 – 200 W
Thanks in advance
Dan
Thanks all for info
rccarguy2
I've never owned MA speakers the only ones I've heard are many years ago, I found them way too bright. I believe new ones are much improved.
Really need to try a few amplifiers out.
Hoku
I would check out the Quad Artera Solus. A tad over budget admittedly.
I’ve not heard the match, but have lots of Monitor Audio experience (have owned many of their speakers: Silver, Apex, Radius, Gold), own the Artera’s smaller sibling, the Vena II, and have heard the Artera in action.
My impression of the Artera was how much current and grip it had for just 75wpc, and that’s typically what a larger floorstander needs. It’s one of those odd enigmas with floorstanders;
They tend to be more sensitive speakers than standmounts, so in other words, they counter-intuitively need LESS watts to produce the same volume output as smaller standmount speakers. But that’s only half the story.
The trouble is with floorstanders is that they produce more bass. And keeping a tight reign on that bass needs high current quality amplification. Sticking quality floorstanders on a cheap amp will produce plenty of noise yes, but will often lack control of the bass, so the bass will sound slow, bloated, and dominate the rest of the frequency range. Not especially nice and usually disappointing.
So I’d certainly be looking for something at the upper end of that budget.
Bear in mind that speaker designers usually voice their products with price-equivalent amplifiers in mind.
Nothing against your friend, particularly if he doesn’t know any better, but it’s not the smartest move to buy speakers and THEN think about an amp to go with it. I just hope his speakers fit in with his room OK. The Silver 300’s probably need a fair bit of space behind them, or to the side of them to perform well.
The only other thought I had is to consider something with built in room correction. But then typically that’s going to be going north of the budget.
EDIT: Just had a brainwave: I’d seriously check out the Roksan Attessa Streaming amp.
Has digital inputs and bluetooth, about £1500 and Roksan and Monitor Audio are part of the same group, so it’s likely that the Attessa would have used MA Silvers in their testing. Should be a great match and offers BlueOS streaming to boot.
3rdignis
