Amp & Surround Sound Processor or New Amp??
Discussion in 'Home Cinema Building DIY' started by funbus, Jan 4, 2005.
  1. funbus
    funbus
    I currently have an Arcam A65 amp but want to upgrade to a surround sound system...
    I'm a bit concerned about the stereo quality I might loose if I upgrade to home cinema amplifier. Would I retain that quality if I used a processor in-line with my Acram?
    Considering I've only got about £300 to spend do you think it would be worth selling the amp and buying a home cinema one (I'm looking at the Cambridge Azur 540)??
    Cheers for any advise...
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    How important is stereo for you as you'd have to get a pretty good AV amp that will do stereo as good as the A65 so you may be better off going for the processor.
    I've never used one so I can't offer any recommendations although I believe that Yamaha do a processor that a number of forum members use.
    John
  3. pm1961
    pm1961
    Jan 2, 2005
    73
    Hants UK
    Hello from a newbie.........
    I've come across from a stereo perspective where I've used a Linn/Naim setup for years.
    There seems to be a real hole in the market for low/medium cost processors (say sub £1k).
    My solution (4 years ago) was to get a well regarded budget Sony AV amp but use the pre-out for the front stereo pair, thereby retaining whatever stereo amp you are comfortable with.
    I've since gone on to use all the pre-outs to full Naim amplification, so now a large box sits there doing only the processing. But, it owes me nothing and does the job.
    My further question would be; how much do you need to spend to better just the processing alone of these budget AV amps?
    Cheers,
    Paul
