Amp (SR7200) settings for SACD / DVD A play (Pio 757Ai)
Discussion in 'AV Receivers & Amplifiers' started by Matthew J Taylo, Apr 25, 2003.
  1. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Hello,
    This may sound like a stupid question but I'm wondering what function on my marantz amp do I listen to SACD & DVD A ?
    Do I set the amp to cd or dvd?
    The cd function is set for analouge input (Ecosse Composers) & dvd is set for digital input (qed SR75).
    I've set up the Pioneer to output the 5.1 sound & I'm asuming this wil be via the x6 analouge interconnects.
    Many thanks:lesson:
  2. Gomez
    Gomez
    Cheers,
    as you've already assumed, you will have to connect your Pioneer DVD via the 6 analogue outputs.
    For the Marantz, press the Button "6-ch-Input". This way, you will use the Pioneer's SACD- and DVD-Audio- Decoders.
    Regards,
    Gomez
  3. Matthew J Taylo
    Matthew J Taylo
    Jan 3, 2003
    164
    19
    Adelaide
    Hi Gomez,
    Yes, I thought it would be simple
    Matt
