Amp + speaker advice
Discussion in 'AV Receivers & Amplifiers' started by Jonfu, Jan 25, 2005.
  1. Jonfu
    Jonfu
    I'm soon to be the owner of the sagem hd 45" beast and i'm now looking for good quality (but not too expensive) amp + speakers to go with it.. and probably a new dvd player. I hope someone can help as i'm new to all this.
    The main thing that is confusing me is HD/HDMI..and anything else with HD in it. So here are a few questions for the experts:
    1. Do i need HDMI on my amp? If so am i looking at a lot of extra cost + is that extra cost worth it?
    2. Do i need hdmi on my dvd player? Again if theres extra cost, is it worth it?
    3. If yes to either 1 or 2 can anyone recommend some good hdmi enabled goodies?
    4. I'll be using my pc through the tv too - whats the best way to connect it? I think my gfx card has dvi.
    and lastly, speakers.. I'm thinking i might go for the MS genies, even if the design is a bit alien..but are they good value for £800?
    Thanks,
    Jon
