hi this is my first post and i need a little help
i need some advice on how to set up 2 amps in my car, on my old system my 4 channel amp and my sub amp were bridgable, so basicly i had one power cable which went into a fused split box which then had one power cable going to the 4 channel amp and one going to the sub amp to power 2 subs, then the 2 amps were joined together by a rca cable then one rca cable from the 4 channel amp to the headunit
now my new 4 channel amp is not bridgable so how do i set these up? can i do it the same way as above?
the 4 channel amp ill be using is a directed audio a1004, not sure on which sub amp just yet but will be a directed/alpine etc.... and will be powering 2 subs
cheers kev
cheers kev
