amp set up
Discussion in 'AV Receivers & Amplifiers' started by PaulaB, May 26, 2002.
  1. PaulaB
    PaulaB
    Mar 6, 2002
    242
    Northamptonshire
    I have set up my speakers up hooked up my dvd player to the amp. HOw do I get the sound data from the dvd to the amp? Its hooked up with a coaxil have I missed something?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    In setup you can configure each digital input. Make sure that whichever digital input you have used is configured to DVD.
  3. Whatts
    Whatts
    Paula,
    Not that easy to answer this without knowing what kind of amp and DVD-player you're using.
    If your amp has assignable imputs, make sure you've got coax assigned to DVD.
    Also make sure your DVD is set up correctly (bitstream out via coax).
    If my post doesn't help, post your equipment so other owners can jump in...
  4. Whatts
    Whatts
    Once again Ian J beats me to the punch...
    - Tom -
  5. PaulaB
    PaulaB
    Mar 6, 2002
    242
    Northamptonshire
    I have a pioneer 515 and a marantz sr6200 how do I get it to bitstream out via coax?
