amp set up
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by bananacat, May 5, 2005.
  1. bananacat
    bananacat
    May 5, 2005
    500
    Milton Keynes
    +14
    please help me with the best way to set up my amp i have just bought an alpine mrp-m350 it has 3 setting on it bass eq, gain and lp filter what would give the best sound :lease:
  2. jason7579
    jason7579
    May 4, 2005
    1,295
    London
    +200
    Is it for a Sub Woofer?
  3. bananacat
    bananacat
    May 5, 2005
    500
    Milton Keynes
    +14
    yep rockford 12"
  4. jason7579
    jason7579
    May 4, 2005
    1,295
    London
    +200
    I'm not familiar with that amp but first adjust the lp filter so you cant hear any thing from the sub apart from bass, but make sure you do it just on the border of hearing mid range through it otherwise you won't get full use of your sub. Then put your headunit onto the loudest you will listen to it, usually about 3/4 way up, and turn the gain up until the sub starts distorting then turn it down to just past the limit where the sub distorts. I keep my gain just under half way, it all depend on the pre-out voltage It is NOT a volume control. Not sure about the Bass EQ but I think it should stay on 0
    Hope this helps, its easier to do it when you have the amp in front of you then explain in writing
