Amp safety lock out
Discussion in 'Hi-Fi Stereo Systems & Separates' started by flappy, Mar 9, 2013.
  1. flappy
    flappy
    Oct 27, 2010
    Hi, can anyone help, I have a problem with my Onkyo AV5VL amp.
    It keeps going into safety (cut out) and silences itself.
    I have tried it with different speaker cable and speakers to see if these are at fault and it still does it.
    However i have tried unplugging the speakers and using headphone jack and it DOESN'T cut out.
    Also curiously today i have tried one speaker plugged in at a time and this also DOESN'T cut out. It only cuts out when i plug in both speakers to the amp at the same time.
    Does anyone know what is causing this?
  2. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,950
    +1,703
    Possibly a fault with the amp protection circuitry or main amp itself, as the headphone amp is a seperate circuit. The only other thought is if you have an issue with the input - may be out an of band signal that you cannot hear but the amp is trying to amplify. Have you tried a different source?
  3. flappy
    flappy
    Oct 27, 2010
    I have tried it with both cd and phono source and it cuts out on both.
    I really need to know if it is the amp at fault, if i send it back they will charge me if the fault is not on the amp.
  4. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,660
    London
    +728
    What are the speakers?
  5. flappy
    flappy
    Oct 27, 2010
    Hi, the speakers are mission M71's
    But also been trying it with warfedale 100se 8ohms
