Amp recommendation for Dynaudios?
Discussion in 'Home Cinema Speakers' started by sbonell, Jan 25, 2002.
  1. sbonell
    sbonell
    Jan 14, 2002
    76
    11
    Woking
    I have bought some Dynaudios (72s front, 42s surround and centre). Now looking for an amp or processor/amp combo to drive these. At the moment I'm still using my old Kenwood Pro-logic which is patently out of its depth (lacks bass on music and is clearly running out of muscle when trying to go moderately loud).
    Has anyone successfully partnered these with an amplification setup they can recommend? I've tried a 3802 which didn't sound that great on music to me (although I may try again to see if the speakers perhaps weren't run-in). So I'm thinking I may need to spend more/go more powerful.
    Stuart
  2. Guest
    In my experience Dynaudio's Audience range mates very well with Rotel power amps. The bigger the better!
  3. sbonell
    sbonell
    Jan 14, 2002
    76
    11
    Woking
    Thanks for the advice. Trying a Denon AVC11SR at the moment. Much better than the 3802 I tried before which I think was struggling with the Audiences. But I'd been thinking about Rotel so will give that a whirl also. Cheers.
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,536
    Newcastle
    +327
    I have heard that Dynaudios like to have a lot of power/current on tap. They're relatively inefficient and drop down to quite a low impedence. As you've found out, a decent power amp (like the rotel) should cope better than just an integrated.
    Cheers,
    Liam
  5. burkey
    burkey
    I use two dynaudio audience 40s for my main front channels . I used to have a Yamaha RXV795RDS amp which had no problems in dealing with this type of speaker .
    Recently I upgraded to a denon 3802 and noticed a great improvement.
    I was told that despite the 40s being 4ohm they were easy to drive and would not present a problem . I have found this to be the case and am looking foreward to putting the 40s on the rear and getting some 42s for the front .
  6. caylem
    caylem
    Oct 23, 2001
    85
    Feels like home to me
    I am currently running a pair of 62s at the front and a 122C centre and it sounds good connected to my 3802.
    What should you look for when trying to best match speakers to an amp? (Whats the impednace??)
    Also what cable would you guys recommend to connect this??
  7. lmccauley
    lmccauley
    Oct 24, 2000
    3,536
    Newcastle
    +327
    The definition of Impedance from http://www.audioreview.com/audio101/glossary/indexi.shtml is:
    "The resistance of a circuit, device or wire to the flow of alternating current. With loudspeakers this is measured in Ohms. Speakers with a low impedance are more difficult to power appropriately."
    I would not recommend spending vast quantities of money on speaker cable (for any speakers). Some people say they can hear a difference - I can't. This has been debated for years, and I'm not going to get involved :eek:
    A rough indication of how well an amplifier can drive a low impedance load is to look at its power rating at 8 ohm and 4 ohm. Ideally an amplifier that is rated at 100W into 8 ohms should be 200W into 4 ohms. This isn't the whole story, however, and there is no substitute for listening yourself.
    From the impedance and sensitivity specs, my current speakers looked to be an easy load to drive, but an Arcam AV50 really stuggled to drive them and I needed to bi-amp with an Alpha 8P to get them sounding decent. Upgrading to an Alpha 10 also improved things :). So, don't just trust the numbers!
    Cheers,
    Liam
  8. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    My BM15s and BM5s seem very happy with a Marantz 9000
    Otherwise I have been told they like Denons.
  9. sbonell
    sbonell
    Jan 14, 2002
    76
    11
    Woking
    Thanks everyone for the advice. I have tried a pre/power Rotel combo (RSP-976 and RMB-1075).
    This was a very noticeable step up from any of the integrated amp options I had tried before with my Dyns. I hope to pick up either this combo or possibly with the new RSP-1066 (depending on price!) which should be launching about now in the UK.
  10. steve1056
    steve1056
    Apr 20, 2002
    384
    Reading
    +5
    I have Dynaudio Contour 1.8's for the front speakers, Audience 122 for the centre and Audience 40's for the rears. They are relatively difficult to drive and need an amp capable of high current delivery. I tried Rotels, but have settled for Myryad amps (MA 240 and MA 360). Everything sounds superb.
    Steve
    :D
  11. Lowrider
    Lowrider
    My speakers are Sonus Faber, but my experience might help, I had Rotel 1080 for the fronts, and although they handled well the easier Concertos, they strugled, and distorted with the Amators...
    I replaced it with the Bryston 4Bst and WOW... Conclusion, the Rotel is quite good, but not suitable to really difficult speakers...
