Amp recomendations to run Sky+, E95 DVDR and Sony Video
Discussion in 'AV Receivers & Amplifiers' started by Tim-Ann, Jun 8, 2005.
Tags:
  1. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,341
    71
    Bradford
    +99
    Hi there,
    Would like to try and cure the lip-sync issues we’re having with Sky+ using an amp with audio delay so can anyone suggest suitable amps to do this.
    We have a PWD7 with dual slot board with component and S-video in and want to connect Sky+, E95 DVDR and a Sony Video which has composite out to the amp and then hopefully just run one set of component cables and audio from the amp to the Plasma.
    I’ve been looking at buying a second-hand Denon 3805 but this would seem to be overkill as I only want to drive a pair of speakers as we are only using the Plasma as a TV no need for surround sound. Are there any other suitable amps.
    Finally how would we connect Sky to the amp I can see that we could connect the E95 via component and the Sony Video by composite but how do you connect Sky+ which has a Scart out?
    Many thanks, Tim.
