Amp / Reciever for B&W 805
Discussion in 'AV Receivers & Amplifiers' started by imho, Jul 6, 2005.
  1. imho
    imho
    I posted in the speakers section of the forum, here and I got alot of tips .. so I decided to get the B&W 805.
    90% of the time, I listen to music, and the rest I watch a few movies with my buds. So I guess I'll go with a stereo solution with the option to "branch out" .. if I find out later that I want to get surround.
    Now that I've decided on a pair of speakers .. what else would you guys recommend?
    Receiver, amp, preamp, poweramp, stereoamp .. it's all pretty confusing ..
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    I've posted a reply in your original thread,but in short,you're going to need a decent,powerful and load tolerant amp.
    One of the best ways to search is to try as many as possible with your speakers,in your own home until you find something that works well.
    If you have the budget to permit it,I'd strongly recommend a processor/power amp solution,and would suggest Rotel at the budget end,and it is also worth looking at used/ex-dem equipment to enable you to buy better for less outlay.
  3. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    I would suggest the new combo from Arcam be given a listen (bit better than Rotel usually)...
    Or a Parasound Amp with a nice used processor (Meridian, TAG)
    If a receiver is the option then the MArantz 9600 would come to mind...
  4. imho
    imho
    People I know keep telling me that I should get a good surround reciever, cause they think that I can't live without surround, and that I'll probably will "go surround".
    "Get a really good surround reciever, it would be less of a hassle for you, as you don't have much hifi experience".
    Someone mentioned the Harman/Kardon AVR7300, said it was really powerful, would work fine with the 805's.
    I just want the "best" sound I can get .. with as few "boxes" as I can (the lady of the house don't like boxes .. )
    :confused:
  5. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
