AMP/Receiver with Analog audio outs ?
Discussion in 'AV Receivers & Amplifiers' started by oaklandraiders, Feb 3, 2003.
  1. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,237
    Surrey
    +47
    Yo
    Does anyone know of any amps that have an analog audio output ?
    I want to use it as an AV switch box into my Meridian, but can only use the video/digital switching at moment.
    john
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Umm, what about using the tape loop connections on an AMP?
    Just use the rec-out sockets, that way whatever analog source you're "switched" to on the AMP should come out from those.
    Does that help at all? Obviously you need to have an idea about how much you want to spend on the AMP.
  3. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Do you mean pre-outs? If so, I have a Yamaha DSP-A1 for sale that has pre-outs. Until recently, I've been using it as a pre-pro driving a Rotel RMB-1075.
    Interested?
    D.
  4. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,237
    Surrey
    +47
    Yo
    Ok tried one of the tape outs, this kinda worked, let me explain.
    Yamaha ax630 using video and digital switching, also 2 front amps to power rear chanels for meridian 568.
    unfortunately the tape out method pumps out that source to my rear channels !
    John
