Amp-Receiver to resolve Lip-Sync problems
Discussion in 'AV Receivers & Amplifiers' started by Tim-Ann, Jun 4, 2005.
  1. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,341
    71
    Bradford
    +99
    Hi there,
    Some advice would be welcome on a suitable amp or receiver to run to a 37PWD7 to resolve the lip-sync issue we are having with this Plasma and Sky+.
    Can we connect the outputs of our Sky+, E95 DVDR and Video into the amp/receiver and then just have one component output from the amp/receiver to the component input board on the Plasma.
    If this is possible can anyone suggest a suitable amp/receiver we don’t need it to drive surround sound or subs this Plasma is just being used as a wall mounted TV but we do need something that will cure the lip-sync problems.
    Any thoughts on something reasonable not over complicated new or second-hand.
    Many thanks, Tim.
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    You could do it this way, but seems pretty pointless to have an amp just to cure lip sync problems!!
    Take a look at http://www.felston.com/. This will solve the sky+ lip sync problems and will be a cheaper option than an amp. It will also take up a lot less room!!!
  3. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    On thinking about it, I am sure you would need an amp to use this.
  4. Tim-Ann
    Tim-Ann
    Jan 18, 2005
    3,341
    71
    Bradford
    +99
    Hi there,
    You do need an amp and of course that would add yet more cabling. Which is moving us towards the amp idea to reduce the amount of cabling going up to the Plasma.
    Tim.
