amp question HELP
Discussion in 'Subwoofers' started by alexWRX, Aug 26, 2006.
  1. alexWRX
    alexWRX
    ok ive asked everywhere and no one has emailed me back about this.
    I just recently bought Two 15 inch Kicker L7s.And each subwoofer has 2 ohms. And I want a 4000 watt amp.Because the peak power is 2000. And I have no idea what amplifier to buy.Do i buy a 2 channel amplifier or mono?I want to buy one from this site http://etronics.resultspage.com/display.php?w=4000+watt&p=Q&ts=dynamic&Store=&image1.x=0&image1.y=0
    Which one will work with my DUAL kicker l7s so i dont have to buy two amps?
  2. Nimby
    Nimby
    Jan 27, 2004
    9,206
    The Danish Bacon Factory
    +671
    The reason you may not get an answer here either is that you are asking about car audio on an HT forum dealing with domestic AV subwoofers.
