Amp problem...........
Discussion in 'AV Receivers & Amplifiers' started by silent, May 7, 2003.
  1. silent
    silent
    Apr 24, 2003
    3,565
    71
    Maldon, Essex
    +80
    i have a Yamaha dspa 595A dts amp, but when playing movies and load base bits come through, the amp switches itself off. it now sounds awful with music to.
    whats the problem, is it fixable or should i buy a new amp?
  2. dood
    dood
    Aug 4, 2000
    943
    28
    Hobart
    +38
    Is this problem new? Have you changed your speakers? Sounds like the amp's internal protection is kicking in because it is unable to drive your speakers as hard as you would like.
  3. silent
    silent
    Apr 24, 2003
    3,565
    71
    Maldon, Essex
    +80
    SPEAKERS ARE OLD TDL RTL3'S. NEVER A PROB IN THE LAST 4 YRS. MUSIC SOUNDS AWFUL TO. THAT NEVER USED TO. ONLY IN LAST 2 WKS HAS IT GOT A PROBLEM. ALL WIRES ARE IN CORRECTLY ETC.
  4. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Amp sounds knackered. Get it repaired or replace it. Don't use it as it is- it could damage your speakers.
  5. silent
    silent
    Apr 24, 2003
    3,565
    71
    Maldon, Essex
    +80
    what i thought, thanks guy's.
