amp power problem
Discussion in 'AV Receivers & Amplifiers' started by chard, May 25, 2003.
  1. chard
    chard
    Dec 12, 2002
    398
    16
    I hope someone can suggest what is wrong with my friends amplifier ?
    He has a high end Denon AV amp (can't remember which model), it is about 4/5 years old and has started to shut down immediately he switches it on ?
    It powers up, all the lights come on, the DD light shows up, as does the error/ overload light - then the thing goes into standby mode...
    What causes overload and what should he do to fix this...?
    many thanks....
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    DIsconnect all inputs and speakers ... does it still shut down immediately. If not then reconnect everything one by one, making sure the connections are good and not touching the case or any other output (this is especially relevant with speaker cables).
    Failing that ... well I don't know ... contact a dealer for advise / repair.
    Vikki
  3. magking
    magking
    Jan 6, 2001
    380
    Norway
    Failing that, try to initialise it.
    See the manual for how to do that.
  4. diesel_uk
    diesel_uk
    Seems like a short like the other users suggest remove all imputs and speaker cables and then switch on. Get a multi-meter check cables etc.Seems more or less Speaker fault.
  5. chard
    chard
    Dec 12, 2002
    398
    16
    many thanks chaps....I am going to try your suggestions
