Amp on screen graphics..
T
Taz
Hi all,
My Amp (Denon 3803) has on screen setup graphics, that are now missing as its being used for audio switching only as I have a Panny plasma.
Whats the best way to get these setup graphics back on the screen??
I have the scart board, BNC component and RGB to VGA connections active on the Panny.
I really dont want to have to swap leads about everytime I need to check the amp settings.
TIA
CARLOS
Are you already using the scart board ? If not then get a S-Vid to scart lead and connect to the monitor out on the amp.
A
Arty
I have the 3802 and a Pioneer 503mxe can I do the same thing? It would be nice to get the O.S.G's back again.
Cheers:)
Joe Fernand
AVForums Sponsor
Taz - what sources are you using and how are they currently wired?
Arty - the AVR-3803 and AVR-3802 differ in that the AVR-3803 has the ability to output the OSG on YUV whereas with the AVR-3802 your restricted to S-Video or Composite; which should be fairly straightforward for you to wire assuming you have the appropriate cable.
Best regards
Joe
A
Arty
Thanks Joe,
I seem to be getting in a bit of a muddle with my new setup! At present it is coupled like this.
1) Sat to vga/plasma converter > r232 port into plasma.
2) Philips freeview via above converter switched through a scart saitch unit.
3)A Tivo unit is in line with the Sat and Freeview units
4) DVD straight to the plasma on Ixos component cable.
I have experimented with an automatic scart switcher Trilogy 2 unit but found it lost the picture regularly, this was frustrating, and I could not find out why. So I had to revert back to the manual box, which is a minor inconvenience.
I have sent off for a SVHS>SVHS Ixos 3m lead which I plan to experiment with. My Sat STB is a Technomate 5500CIP+ and this has a SVHS connector on the back. I plan to try going from the sat to the amp on SVHS and use this as the switch, couple the component leads to the amp and see if I get a picture. I am not too sure if this will work as it will be SVHS to component and I know some cheaper switch units do not operate performing operation such as this.
I'll let you know how I get on when I get the lead delivered.
Regards,
Arty:smashin:
T
Taz
Originally posted by Arty
Just updated profile to include new sat.
Arty:clap:
:offtopic:
Anyhows... I have it sorted now, thanks.
Running DVD via component into the amp and up to the plasma.
:smashin:
Podcast: REL T9/X Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
