Amp on or off when not in use
Discussion in 'AV Receivers & Amplifiers' started by pr1uk, Dec 24, 2003.
  1. pr1uk
    pr1uk
    after reading a response on another thread from cfczeek i was interested in his comments
    "(Assuming you don't switch the amp off either, which you wouldn't if its a decent amp)"
    now i have a decent Amp and have always turned it off when i go out or overnight, so come on lads and lassies whats best On or Off..
  2. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    I personally think this is an old wives tale that stems from the days when amps sounded better when warmed-up compared to when they are 'cold'. Modern electronic amps should work well straight-away, or at least settle down fairly quickly after they are switched on.
    The other argument is that electonics are more likely to become defective if they are cooled down and warmed up, as opposed to if they are just left on. Again, a quality amp shouldn't break-down whatever you do.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    My Arcam's are on 24/7 and my 3802 is also on, but put into standby when not in use. They only get powered down when I'm away from home for a week or more.
    I also leave my PC on 24/7 as I believe that electronics are put under the most stress when being powered on and regardless of the quality of the unit, constent power cycles do shorten their life. My CD & DVD are only powered on when used, but I can hear the difference as the unit warms up over an hour or so.
    Mark.
  4. pr1uk
    pr1uk
    thats me i leave mine on standby when not in use and it sounds great. cheers
  5. DaveP
    DaveP
    Just one caviat! Don't leave your receiver in standby after listening to the radio!
    We had a power cut one night and when the power was restored the receiver came back on and out of standby. Made me jump out of my skin at about 3:00am in the morning!
    Dave
