amp JBL755.6 problem!
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by scoobystan, Aug 6, 2005.
  1. scoobystan
    scoobystan
    just installed a brill system into my car today, saved mesef £200 fr a job i put just as much time and effort into completing.
    Gone to power up system and amp has no power?!
    checked the earth and power suppy with a volt meter and both are fine, can ony think its the amp which is busted (its brand new out of the box) or the remote cable not connected correct, any ideas??
  2. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Run a short length of wire from the +ve to the rem terminal,that should now energise the start up realy and power up the amp.Don't leave the amp like this as it won't power down and a drained battery will result.
