Amp Help
Discussion in 'AV Receivers & Amplifiers' started by kocl, Dec 22, 2003.
  1. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    i'm choosing an av from Pioneer ax5i, Marantz 7400 or onkyo 701.
    What do you think is the best?
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    The amps are each in different price brackets, so it's difficult to compare them.
    The Pioneer will deliver the best audio quality, but I think it's the most expensive (not familiar with the Onkyo).
    Dimmy
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi kocl
    What is the rest of your kit ie speakers as this can be a deciding factor at what to get amp wise.Also will the receiver be used for music as well as movies.
    Cheers Gonzo.
  4. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    hi, the kit is made of
    DVD Pioneer 757
    Speakers KEF Q55.2/Q15.2 and Q9C
    for front speakers Musical Fidelity A3.2, connect the preamps of av.
    sub MJ Acoustics REF 100.
    Sanyo Z2
    The receveir is of movies only, since the MF will do the music,
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Kocl
    Go for the pioneer m8.
    Cheers Gonzo.
