Amp/Headphone Pairing Question
johnnymaelstrom
Through chance - as I had the kit lying around - I've started using an SMSL M6 Mini DAC and headphone amp with Sony MDR-XD200 over the ear headphones for my working day listening. Reading up on impedance and sensitivity I was curious about this pairing.
The headphones have an impedance of 70.0 Ohms (link) and sensitivity of 102.0 dB/mW.
The headphone amp manual says the following range of impedances:
33 Ohms at 130mW
66 Ohms at 270mW
150 Ohms at 220mW
300 Ohms at 120mW
How do they pair and also what I would do to improve the sound. I know these are not the best kit around, but I hope to learn from this for any future purchases.
  • Are the amp and headphones adequately paired at the moment?
  • If I was thinking about a new headphone amp what range of impedances should I be looking at for these headphones?
  • If I was thinking about a new set of headphones what range of impedances would I need to look for this headphone amp?
Steven
Senior Moderator
70 ohms 102 db is not that hard to power. Your DAC amp would drive the Sennheiser HD600 / HD650 for example
No comment on quality, never heard the unit
johnnymaelstrom
Thanks for your reply. I can’t find the impedance for the Sennheiser headphones. Are they the same/similar to my Sony’s so that’s why my amp will power them or is there a calculation or rule of thumb you used to work that out?
Steven
Senior Moderator
Bedtime reading:
70 ohms and 102db sensitivity is relatively easy to power
The HD600 and HD650 HDD have been headphone benchmarks for 15 years. 300 ohm and 97db sensitivity
johnnymaelstrom
Bedtime reading:
Thanks, looks like my kind of analysis.
When you say the Sennheisers are benchmarks did you mean that my amp can drive them so I should have no problem with any decent headphone as they should be compared to the Sennheisers?
Steven
Senior Moderator
No, benchmark in the sense of famed balanced audio quality at a reasonable price
300 ohm 97 dB sensitivity requires more power to push to a listenable volume than 70 ohm 102 dB. However thanks to modern connected economies and everyone opening a factory, even a budget device like your SMSL can power the Sennheisers 😎
Podcast: Sony A90J Thoughts, madVR Processor & Sonus faber Lumina II Reviews + Movie & TV roundup
