Amp has Euro 2 pin plug.. if I change to UK what fuse?
Discussion in 'AV Receivers & Amplifiers' started by CRNeo, Sep 6, 2007.
  1. CRNeo
    CRNeo
    Aug 29, 2007
    4
    Got a Sherwood RD6106R DTS amp cheap but it's got a Euro 2-pin plug on the end.
    I assume there should be no problem cutting the plug and putting a UK 3-pin on but anyone any idea what size fuse I should be using???
    Many Thanks
    Craig
