amp from u.s.a power question
Discussion in 'AV Receivers & Amplifiers' started by fender62, Feb 23, 2005.
  1. fender62
    fender62
    Jan 11, 2005
    144
    19
    cowbridge
    i can buy a used SONY AMP MODEL AX-401 buts its american what sort of
    step down do i need or would the amp be auto switching, i cant find any info on the amp.im not sure how old the model is or how much they originaly cost
  2. machinehead
    machinehead
    Sep 5, 2004
    466
    Greenock
    +12
    do a search on the forum fender.i think you'll find it's more hassle than it's worth.for what you you save in the amp you'll spend double trying to convert the power supply into 240.
    regards machinehead
