ziggyzog
I'm new to this, so please be gentle. I've searched previous posts and can't find an answer to my question.
I have a standard Sony AV amplifier which I have previously connected up normal speakers to. I've got the chance of buying some Tannoy ceiling speakers (Tannoy CMS 501 BM) at a very reasonable price but looking at the specifications now, I'm a bit worried they won't work with my amplifier.
Tannoy | Home
They have transformer taps which I understand can be used with PA amplifiers and rigging up multiple speakers. There is a switch/dial which can select options of voltage/wattage with also an OFF and low impedance operation.
I just wanted to check if the OFF or low impedance operation options would work OK with my current amp?
Thanks for any advice.
Mike
http://tannoy.com/residential/#!products_1473
Tannoy | Home
Mike
