Amp For Kef Q4's
Discussion in 'AV Receivers & Amplifiers' started by Simba, Jul 3, 2004.
  1. Simba
    Simba
    HEY
    im wanting an audio setup for movies and listening to music. im not currently interested in surround sound (budget) so im going for the L+R speakers at the moment.
    the speakers im interested in are the kef q4's .....since reading the review http://www.kef.com/reviews/pdfs/uk/uk_Q AV WV 0604.pdf
    in last months mag june 2004.
    my problem is that i dont know of a suitable amp to power these speakers. for audio and dvd ill be using the awesome sony dvp-ns930. so i want an amp that can do these speakers the justice they deserve. im looking to spend around the same as the speakers, £400-450.
    the denon 1804 luks good but im not sure......plz hellp!
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    If you can strectch your budget a little bit the Arcma AVR200 at £600 from any Sevenoaks would noticebaly ouperform anything else at that price point for stereo reproduction. If youn are looking for something a bit swicher with more bells and whistles (but usually lower sound quality) then the new Pioneer VSX-D814 would be worth an audition.
  3. Simba
    Simba
    i checked out the review of teh arcam u quoted but i wasnt impressed. instead i checked out a pioneer, the vsx d912......and with a 5 star review and brilliant features im almost convinced that this is the amp for me..........wot do u think??
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Marantz PM 7200 or 7200 KI... :thumbsup:
  5. Simba
    Simba
    is that for home cinema aswell? u see im wanting the amp to be for home cinema and music but i plan on buying the additional speakers later.
    the pioneer luks pretty good ? any other quality amps in my price range?
