Amp for an HTPC
Discussion in 'Computer Components' started by vbtrek, Jan 12, 2008.
  1. vbtrek
    vbtrek
    Can anyone recommend a cheap 5.1 Amp with optical input for my HTPC, and in black. I currently have some cheap Sony 5.1 PC speakers attached to the machine and they don't sound very good.
    I would also need a sub woofer, i'm hoping to use the satellites from the Sony setup initially.
    Appologies if this is the wrong forum, i'm new here.
    Thanks.
  2. Gixxerblade
    Gixxerblade
    Nov 19, 2004
    462
    +45
    It depends what you call cheap but you can pick up a second hand Arcam AVR100 for about £150 and the 200 for a bit more. I used the 100 for 5 years with a digital coax connection and really rate it. You can send the front pre-outs to a dedicated stereo amp if you want to in the future which is how I used it with an Arcam A85.
    A REL Q100E sub is working well in my room at the moment, a lot depends on your room, you can pick one up for £150 second hand, if you want new then try BK and SVS and have a look at the sub woofer forum.
    I'd replace the speakers first though, buy a stereo pair - the best you can afford and buy the sub and surrounds later as funds allow.
  3. Croatoan
    Croatoan
    Jan 7, 2008
    401
    28
    +59
    If you have £200 to spare, consider the logitech z5450 system. Has 2 optical in, coax and pc connectors.
    Have one in the front room and sounds great. Supports DTS and THX.
    They also do a wired rear Z5500 which is also around the same price.
    You get the whiole hog in one discreet package.
