Amp & Floor Standing Speakers <£300 ?
Discussion in 'AV Receivers & Amplifiers' started by bigdic, Sep 20, 2007.
  1. bigdic
    bigdic
    Dec 5, 2004
    83
    +3
    Hello guys and gals,
    Just put together and HTPC for the folks and now they've decided they'd like an amp and floor standing speakers with a budget of under (the lower the better) £300.
    The only absolute requirements are a co-ax digital input, floor standing speaker and it must be silver (you can tell they're very technical!)
    I've had a look but having trouble finding it all including the floor-standing for the under £300 mark. Does anyone have any recommendations they could help me with please?
  2. dazza74
    dazza74
    Aug 24, 2006
    13,037
    +1,394
    Does the amp have to be surround sound. If it does then I reckon your minimum budget new would be about £400 for both, you might want to have a look at the classified ads on here, lots of people upgrade on a regular basis and probably some good quality stuff at a good price.
