AntonioFI
Hi to all,
I"m looking for an headset amplifier + DAC to be used with my AKG K612Pro (120Ohm).
As an input an USB could be enough, considering the Bluetooth as an option, since I'll use my smartphone as source.
Device footprint shall be small since I have little space.
Budget is around 350€, even if I could add 100€ for a significant improvement.
Up to now I'm considering the Schiit combo Magni3 + Modi, the Topping Ex5 and I'm curious about the Aune T1SE (tube sound).
What's your opinion?
Any other advice or suggestion?
thanks a lot
thanks a lot
